Hi, I have just receive my stepper motor and a4983 stepper driver! I successfully drive the motor using a Netduino controller!
I am building a circular platform that need to move from an initial position to up to 5 other positions (about 33.3 degrees apart). A certain delay (5-30 min) will occurs before to move to the next position. I would like the stepper motor to at least move back to the initial position (home state!?) when powered up and/or using another trigger signal (Other wise I would have to use a manual switch move the motor to the starting position which is less sexy).
Does the RESET feature meant to do that? If yes, how do it work?
I tried to flash the RESET pin with 0V or 5V without any success.
