# Stepper motor operation at high speed
**URL:** https://forum.pololu.com/t/stepper-motor-operation-at-high-speed/12660
**Category:** Motor controllers/drivers and motors
**Created:** [May 18, 2017, 6:43pm UTC](https://forum.pololu.com/t/stepper-motor-operation-at-high-speed/12660 "2017-05-18T18:43:48Z")
**Posts on this page:** 1
**Showing post:** 2
<div class="post-metadata">
### Author: ![nathanb](https://forum.pololu.com/user_avatar/forum.pololu.com/nathanb/32/799_2.png) [@nathanb](https://forum.pololu.com/u/nathanb)
#### Post date: [May 19, 2017, 9:22pm UTC](https://forum.pololu.com/t/stepper-motor-operation-at-high-speed/12660/2 "2017-05-19T21:22:23Z")
</div>
We do not have a specific recommendation. The pulse rate-torque graphs (sometimes called pull out torque curves) in stepper motors’ data sheets are a good place to look for information about how well the stepper motor can handle high step rates, though other aspects of the system can have a large effect on the maximum step rate. You can read about results from varying the power supply voltage and using a flywheel with a different stepper motor in [this post on our forum](https://forum.pololu.com/t/max-step-frequency-for-1206-stepper/5794/6).
The [datasheet for the SS2502 motor](https://www.pololu.com/file/download/SS2501.pdf?file_id=0J612) you have makes it seem like you might be able to get the motor running faster than ~600rpm (about 4 kpulses/s in the half-step pulses the graph in the datasheet uses). What supply voltage are you using right now?
-Nathan
_[View the full topic](https://forum.pololu.com/t/stepper-motor-operation-at-high-speed/12660)._
