I am trying to talk to a SSC03A micro serial servo controller, from an AVR uC.
I have tried using my code, ruby’s array.pack, and also the pololu serial transmitter using Mono (through the usbavr in a straight USB-Serial mode from LUFA) all without success.
Whenever I send any command, the servo controller flashes its red light forever, and keeps the yellow one on.
The datasheet leaves me none the wiser as to the meaning of that, other than it is some kind of error.
Monitoring the serial output line, I get 0x80 back when this happens, but again the datasheet fails to explain any of the serial response codes.
An example command I am trying to send (jumper off - pololu mode) is
0x80 (start), 0x01 (device ID 1), 0x00 (set config), 0x01 (servo id), 0x4f (turn on this servo, leave other settings at defaults)
In the Mini SSC II mode, If I send something like 0xFF,0x01,0xAA then a servo twitches initially, but then I get the same error condition and no more response until I reset it.
I have tried both serial inputs. The inverted one gives me a baud rate error as I would expect, as it doesn’t see it’s 0x80 start byte.
I am running Linux, but I don’t see why that should be a problem. I have the serial port set up at 9600 baud, 8 bits no parity, no flow control etc. Plus the official app seems to work under mono, i.e. it does send data to the serial port.
Any ideas?
