Working on a prototype for a firefighting robot so I can try out some different sensors, code etc. It isn’t much at the moment, nowhere near done (will post updates here and on my blog) but… its red
The final version will be differential steer with larger wheels more centrally located, but the goal here was to build uber-cheap with parts on hand so… here we are.
well, after fighting with brown out resets on the BS2 when trying to power the motor, and having no luck with the servo, I managed to get both resolved. Fits and spurts.
So, the servo is back on and under MCU control, and the motor can now be powered up and controlled with PWM. Just have to tie the board and batteries to the bot before burning rubber. More later…
Got Sparky rolling on his own under power by a BS2. This answered my questions about motor/geartrain performance. So I put in an order to the good folks at Pololu just now for an Orangutan LV168, Tamiya gearbox, tires/wheels, and a few other goodies so I can start building the competition bot. Very excited to get started on the “real” firefighter…
Purely for entertainment purposes here’s a video of the build / test:
Thanks much! I have (way too much) fun making the videos, what can I say? Just hoping the bot turns out ok
I was going to build the motor control and everything else entirely from scratch but a guy’s gotta know his limitations I guess. I think the Pololu LV168 setup is going to be far more reliable and let me concentrate on sensors & software.
Wow, just under 30 days left Where is the time going??? I am getting a little freaked out by how much is left to do. But the Orangutan LV-168 is great and programming on a Mac is superb. Sparky continues to be a very useful prototype. Here’s what I’ve been up to.
Quick question – I am getting ADC noise with the motor on – what can correct this, cap across the motor leads?
I have a Sharp GP2D12 heading my way hopefully today so I can mount it and the flame sensor on a servo and work on the navigation and flame detection software tomorrow at the local club meeting. Meanwhile I’m anxiously awaiting the arrival of my “secret weapon” in the mail…
Nice video! Noise is generally a problem with the Tamiya motors, and the switching regulator on the low-voltage Orangutan can make things even worse. You definitely want to put three caps on each motor: one across the leads and one from each lead to the case. Try to keep the wires going to the motor as short as possible and as far away from your analog signal wires as possible. It looks like you might already be doing it, but twisting the motor wires also helps.
If you can afford to do lower-frequency sampling of your sensors, the next things I recommend is averaging several samples (or something like that, depending on how much processing overhead you have). For some powered sensors, it can help to put bypass caps right on the sensor power inputs.
Looking good! And especially good job building testbeds for everything, instead of trying to cram everything onto Sparky at once. Good luck, 30 days is not a lot of time!
Thanks for the replies. Jan, thanks for the help on noise, really appreciate it. I’ll give each of those things a whirl. Hopefully the caps on the motor(s) will help.
Well, poor Sparky has been decommissioned and mostly disassembled to make it possible to build the competition robot, Pokey.
I’ve been working on that the last few weeks and it’s now mostly done! (ok, it needs paint, I know…)
I settled in on using a lantern flashlight reflector and IR LEDs for flame/heat sensing pointing backwards. That way the robot can scan and then back up to the flame in a straight line from the doorway, then simply move forward in a straight line back to the doorway once the candle is extinguished and continue back home. If there’s no candle, the scan ends with the robot pointing to exit the room and continue the search.
An Op Amp amplifier is mounted to the back of the sensor (front of the bot). After some fussing around with the layout I came up with a 3 deck arrangement, with the Orangutan LV-168 sitting on deck 2 in the back (have I mentioned lately how happy I am with the controller? )
The dual motor gearbox + tires sit on deck 2 along with the batteries (above the motor). The oddball servo-mounted ranger array sits on the front of deck 2 taking up a load of real-estate but it works for short or long range sensing and can look left or right while watching for obstacles up front. Wall following prototype code is done and works pretty well. I still need to make the floor sensor.
Now it is a matter of doing a ton of coding. And figuring out the water-based fire suppression which continues to be a challenge.
Thanks Though Sparky is in pieces, Pokey – his successor – did ok in the comp and I do have some plans for improvements.
Speaking of video, here are excerpts from the competition I threw together.
Anyhoo… my club may do a competition later (April? May? I dunno)… I have some plans for Pokey to be sure… because I want to crush the competition this time.
His main problem is wall following. I had to slow him down (hence the name) and didn’t get around to adjusting the wall following… so he couldn’t reliably orient parallel to a wall or end up in the corner of the room upon entering-- both are foundational to the rest of the navigation working really well.
Other changes/fixes…
Fix the 100uF SMD cap I broke off the LV168 board
Replace the battery tray whose leads broke off about 5 minutes before the competition started (had to hand wrap them back on…!! )
Finish the code to get Pokey from the 3rd to 4th room (of some importance) …
Replace the rear slider since it hangs up on the paper surrounding the candle (bad)
Fix and speed up the candle scanning / finding routine (fairly important too)
Redo the fan driver circuit and maybe do dual fans since I have two airplane props and two motors handy…
That’s the critical stuff, I guess.
And… while I’m at it, if I can get the navigation working consistently, I am going to try speeding him back up. He was definitely the fastest of the crowd even in his intentionally detuned state… but he’s got a LOT more under the hood.
I thought you might like to see, PopSci has an article up on their website (finally! it was in last month’s print edition) about a cool autonomous forest fire fighting robot (concept, oh well).
Wow, that’s really cool. Maybe someday it’ll become reality…
I’m still waiting for Asimov’s vision to come true.
On another note, I was able to get a 100uF cap back on Pokey’s LV168 board – and didn’t even scorch the board too badly Replaced the battery tray and did some reinforcing to prevent another wire failure. So… I think Pokey is mechanically sound again!
I’ve been holding off on much else until they announce the next FF competition since I have a lot on my plate these days.
