Is is possible with one analog input to configure the motor to use the full scale analog input to control speed in forward direction only??
Thanks,
Thanks,
Hello, Steve.
Yes, this is possible.
To prevent the motor from moving in reverse, I would first go to the “Motor Settings” tab, check the “Asymmetric” box, and set the max reverse speed to 0.
Then to make it use the full range of the analog input, I would configure the input like this (use the scroll bar to see the whole image):
