Using the standard settings with Pololu control center will only move the servo through 90 degrees. I tried resetting the min max settiings to greater values with no effect. How can the settings be changed in a simple fashion to move the servo through 180 degrees?
If your servo can do more than 90 degrees, this FAQ will help you achieve that:
pololu.com/catalog/product/1351/faqs
Did you remember to click the “Apply Settings” button after changing the min and max? Could you tell us what pulse widths you have tried and how the servo behaves at those pulse widths?
I missed the “Apply Settings” button! I use a minimum pulse width of 500 and maximum pulse width of 2500 to get 180 degrees rotation.
