Is the set multi command available in the servo scripting language on the servo controllers?
Thank you,
Jerry
Thank you,
Jerry
Hello, Jerry.
Unfortunately, there is not a command to set multiple servos at once. Have you tried setting each servo separately and found it was too slow?
- Jeremy
Thank you for the response. I am moving 2 horizontal surfaces that are attached riding on bearings, one servo must travel in reverse the other forward, I have not tried driving both servos on this surface I just wanted to make sure I could start/stop servos 2 at once. The delay may not cause the servos to fight each other. If it does, I will user a Y cable and either mod the servo to operate in reverse or use a reverser.
Jerry
