I have read the manual and wired everything up like it says. Am using a 5V 12 amp regulated power supply and have it hooked to the power supply terminals on the Maestro 12 and have the blue jumper on the VIN and VSRV pins as I will be using one power supply and will not have it connected to a USB port.
The Program works as I have tested it in the control panel and is as follows: But when in stand alone not connected to the computer it will not move any servos. What am I missing here.
goto main_loop # Run the main loop when the script starts (see below).
# This subroutine returns 1 if the button is pressed, 0 otherwise.
# To convert the input value (0-1023) to a digital value (0 or 1) representing
# the state of the button, we make a comparison to an arbitrary threshold (500).
# This subroutine puts a logical value of 1 or a 0 on the stack, depending
# on whether the button is pressed or not.
sub button
0 get_position 500 less_than
return
# This subroutine uses the BUTTON subroutine above to wait for a button press,
# including a small delay to eliminate noise or bounces on the input.
sub wait_for_button_press
wait_for_button_open_10ms
wait_for_button_closed_10ms
return
# Wait for the button to be NOT pressed for at least 10 ms.
sub wait_for_button_open_10ms
get_ms # put the current time on the stack
begin
# reset the time on the stack if it is pressed
button
if
drop get_ms
else
if drop return endif
endif
repeat
# Wait for the button to be pressed for at least 10 ms.
sub wait_for_button_closed_10ms
get_ms
begin
# reset the time on the stack if it is not pressed
button
if
else
drop get_ms
endif
repeat
main_loop:
begin
6000 1 servo
6000 2 servo
6000 3 servo
6000 4 servo
6000 5 servo
6000 6 servo
6000 7 servo
6000 8 servo
8000 1 servo
8000 2 servo
8000 3 servo
8000 4 servo
8000 5 servo
8000 6 servo
8000 7 servo
8000 8 servo
repeat
return
Dan S.
