Hi, I posted about a week ago asking for battery advice and since then I have bought a micro maestro, connected up two power sources, successfully completed a sequence and run it through the maestro as a standalone unit
Iām obviously very happy that Iāve managed to do this so thanks very much so far for the help.
Now - Iāve seen some posts about altering individual frame speed settings, where you go in and tweak the script. Could another way be just to create many frames which play quickly and build in the servo movements that way? IE do 20 discrete movements one way at small intervals of rotation, and then do 20 movements back in a larger increment, effectively making the servo accelerate in one direction faster than the other? Obviously Iād have to put some speed setting on the whole sequence to even out the motion and prevent it from jittering.
Iām basically thinking of using the frames like a flip book.
The main downsides would be the time involved in creating these frames, and the other would be the capacity of the memory onboard the maestro. So, if I went down the route of thousands of frames, is there any way of increasing the capacity of the maestro? Could I copy the script onto a flash drive and plug it in?
Your thoughts would be helpful
