Hello, I need your help to create a small program for my 6-channel controller.
Should I connect two servo motors, which carry out the same movements.
The two servo motors should move continuously from -30 ° angular degrees to + 30 degrees angle, and the minimum speed.
I would be very grateful if someone would write here the necessary strings.
Thank you in advance for any help.
…Nothing ??
You can use the Maestro sequencer to get that kind of motion from your servos. Emily goes over how to use the sequencer in our Getting Started with the Pololu Maestro Servo Controller video (at about 3 minutes 40 seconds) and we document how to do this under the Sequencer section of the Maestro’s user’s guide, which is located under the Resources tab of its product page.
-Jon
