leodh
May 24, 2014, 2:47am
#1
I have a Raspberry Pi ( Rasbin Wheazy ) and would like to use it with my servo controller ( Mini Maestro 18 ).
Is it possible using USB
What software/drivers do I need
Is there any sample program code I could look at
any info would be great.
Thanx Leo
Hello, Leo.
Yes, you can control the Maestro over USB from a Raspberry Pi and several people have done it before. There are two main ways to do this: you can use the Maestro’s native USB interface or you can use the virtual serial port. You can find more information and example code in Maestro User’s Guide . The relevant sections are named “Writing PC Software to Control the Maestro” and “Related Resources”.
jwatte
May 25, 2014, 3:55am
#3
I’ve done exactly that! Except with a Micro Maestro. It works great.
I control it using the virtual serial port.
Here’s some code:
int fd = -1;
bool open_servos(char const *n) {
fd = open(n, O_RDWR, 0600);
if (fd < 0) {
perror("open");
return false;
struct termios tio;
if (tcgetattr(fd, &tio) < 0) {
perror("tcgetattr");
return false;
cfmakeraw(&tio);
cfsetspeed(&tio, B9600);
if (tcsetattr(fd, TCSAFLUSH, &tio) < 0) {
perror("tcsetattr");
return false;
return true;
void update(double d, unsigned char *b) {
if (d < -1) { d = -1; }
if (d > 1) { d = 1; }
unsigned short t = (unsigned short)((1500 + d * 500) * 4);
if (t > 16363) {
fprintf(stderr, "rmaestro: steer %f generates value %d which is too big\n", d, t);
return;
b[0] = (unsigned char)(t & 0x7f);
b[1] = (unsigned char)((t >> 7) & 0x7f);
void write_servos() {
unsigned char cmds[16] = {
0x84, 0x00, 0x00, 0x00,
0x84, 0x01, 0x00, 0x00,
0x84, 0x02, 0x00, 0x00,
0x84, 0x03, 0x00, 0x00,
update(fr + d_fr, &cmds[2]);
update(fl + d_fl, &cmds[6]);
update(rr + d_rr, &cmds[10]);
update(rl + d_rl, &cmds[14]);
int w = write(fd, cmds, 16);
if (w != 16) {
perror("write");
fprintf(stderr, "rmaestro: short write: %d/16\n", w);
exit(1);
The “fr + d_fr” calculate the steering I want for each of the four channels I use, between -1 and 1.
You can change it to whatever you need.
