I have a problem with my servo controller. My servo only moves for about 45 degrees. Can anyone help me figure out what is wrong with my code?
This is my hardware setup:
Windows PC -> USB -> Pololu MICRO servo board -> Servo (channel 0)
Power supply (6.8V, 5A) -> Pololu MICRO servo board
I have set the settings to “Dual Port”
I am sure power supply is not a problem since I have more than enough power for my servo. The servo works perfectly when I try using the Maestro control center.
This is the code that I am using (python 2.7, all libraries installed - no error messages):
import serial
import time
import math
from Tkinter import *
master = Tk()
w = Scale(master, from_=0, to=180, orient=HORIZONTAL, length=180, label='Angle')
w.pack()
speed = 100
class ServoController():
def __init__(self):
self.sc = serial.Serial('COM3', 115200)
def closeServo(self):
self.sc.close()
# Define the set angle function
def setAngle(self, n, angle):
# Define byteone variable as the percentage of 254
byteone=int(254*angle/180)
# chr(i, /) = Return a Unicode string of one character with ordinal i; 0 <= i <= 0x10ffff.
# Define the bud variable as:
# chr(0xFF) = command bytes (most significant bits set (pg. 49 manual)
# chr (byteone) = data bytes
# The pololu servo protocol is always command bytes followed by data bytes
bud=chr(0xFF)+chr(n)+chr(byteone)
# Write the data to the serial port
self.sc.write(bud)
# Define the servo speed function
def setSpeed(self, channel, speed):
# This is the set Speed compact protocol (pg. 55 manual)
# Compact protocol: 0x87, channel number, speed low bits, speed high bits
commandByte = chr(0x87)
channelByte = chr(channel)
lowTargetByte = chr(speed & 0x7F)
highTargetByte = chr((speed >> 7) & 0x7F)
command = commandByte + channelByte + lowTargetByte + highTargetByte
self.sc.write(command)
Maestro = ServoController()
def controller():
global speed
Maestro.setSpeed(0, speed)
angle_dest = w.get()
try:
Maestro.setAngle(0, angle_dest)
time.sleep(.05)
except:
time.sleep(.05)
w.after(1,controller)
w.mainloop()
basically what the code does is it displays a slide bar for controlling angle (0-180). But, what I actually got is if I move from 0-90, the servo does not move, and from 90-180 the servo moves 45 degrees.
Can anyone help please? It’s urgent
Thank you so much!
