I am using a Pololu Micro Maestro Controller to control a Torxis Rotary Servo i00800 from Invenscience LC.
According to the specification of the Servo, it is supposed to have a rotation range of 270 degrees. However, it only rotates about 200 degrees.
In the popolu Maestro Control Center, the range for the target position is from about 400 to 2600(us). outside this range, the servo does not react.
Does anyone know, how I can use the full range?
Thank you for your help
