I have a 1501 MG Servo. I just want to let him run forwards and backwards. I want to connect it to an Arduino UNO. I am not an expert - I just need it for one project. Does anybody has a sketch and could explain me how to wire the servo to the Arduino? It would be really helpful. Thanks so much for your help. Best, Anton
You could probably use the Arduino Servo library to control your servo movements. The Arduino Servo library page lists the connections you should use for the servo, and the Sweep example lists the pin you should connect the signal wire to for that example. If you post a wiring diagram of your proposed connections, I would be glad to look it over.
