Serial_set_baud_rate(9600); for 20 mhz and 16 mhz clocks
Thank you Amanda for your quick reply.
I already tried your suggestion, trying to debug the problem. Of course your suggestion doesn’t work. Since my baby-O is running at 20 mhz and the Uno that I’m using runs at 16 Mhz. I’m trying to use the code that runs on the baby-O on the Uno. Different clocks prevent from setting the correct baud rate. I’m NOT trying to connect the baby-O and Uno to talk to each other. I’m using a bluetooth HC-05 module to talk to my host.
But yesterday I found a post on the forum, that did the trick! Tried it and it worked. Looks like the post on the forum was posted in 2008. But it appeared as a new topic. Here’s the link to the post on your forum: I/O question in programming
Since this suggestion worked, I CAN now communicate with the Uno at 9600 baud.
Thank you again for your prompt reply. I wish to send an addendum to my original post, as a solution, but don’t know how.
Cesar
Adam, Just noticed that one of the PC pins/IR does respond at the LV-168. While connected three stay at Nesw no…
](I/O question in programming)
