I’m trying to send commands to the TReX via the serial port using a rabbit 3000.
here’s a code snipet:
char retStr[15]; // string for returned characters
int retStatus;
serBopen(_232BAUD); // _232BAUD is set to 19,200
serBwrFlush();
serBrdFlush();
serByte = 0x82; // get mode command, should return one byte
retStatus = serBputc(serByte); // byte sent. retStatus = 1
serBread(retStr, 15, 250); // read serial port. returned value should be in retStr.
retStr is either empty ("") or junk.
I have tried several TReX commands with no response from the TReX.
I suspect the serial port may not be setup correctly.
I believe the default TReX setup is baud = 19200, no error checking, one stop bit.
Spent several hours trying all sorts of settings and no luck.
Any help would be appreciated
