Hi all
i m trying to develop c code to access serial 8 servo controller , i m using the program that is posted on this webste pololu.com/projects/prj0003/ssc-tester.zip . Basically i m using ssc.c file and i try to access the functions in there. I m trying the following code here it still does not work. any suggestions ?
#include <stdio.h> /* Standard input/output definitions */
#include <string.h> /* String function definitions */
#include <unistd.h> /* UNIX standard function definitions */
#include <fcntl.h> /* File control definitions */
#include <errno.h> /* Error number definitions */
#include <termios.h> /* POSIX terminal control definitions */
#include <sys/select.h>
#include "ssc.h"
int main(){
ssc s;
connectSsc(&s);
enable(&s,1,1,1);
stepTo(&s,1,1,2000);
endSession(&s);
return 0;
