Script issue with speed
Yeah, it is me again :slight_smile: I’ve noticed that for some reason when I copy my script to the micro maestro it does not copy the speed/acceleration outputs. Any idea why this would be please?
Thanks
Copying just the script onto the Maestro does not copy the Maestro settings. You can load both the settings and the script from the settings file. The settings file can be saved by selecting ā€œSave settings fileā€¦ā€ under the ā€œFileā€ menu; similarly, selecting ā€œOpen settings fileā€¦ā€ in the file menu allows you to load a settings file. Please note, you can set speed and acceleration in both the ā€œStatusā€ and ā€œChannel Settingsā€ tabs, but only the settings in the ā€œChannel Settingsā€ tab will save to the settings file.
- Grant
Thanks for that!
I have since tried changing the options in the channel tab and it worked a treat. Thanks again for your help
