Guys
With the Roborealm module for Maestro only 12 of the 24 servo will work.
The 1st 12 are ok but the 2cnd 12 are grayed out.
Has anyone else come across this. And is there an easy answer.
The 24 servo driver is installed.
Thanks
Arobo
Guys
Thanks
Arobo
Hi, Arobo.
I just tried using RoboRealm 2.24.14, and I have the same problem as you. The servo checkboxes just under the “Channel #” label are disabled on the tabs called “Servos 13-18” and “Servos 19-24,” but not on the other two tabs. I am going to report this as a bug on RoboRealm’s web contact form.
- Ryan
Update: I tested the 6,12, and 18 channel Maestros, and they all seem to work fine. I have also reported the bug to RoboRealm.
Thanks for the feedback. At least I know its not just me.
Thanks
Arobo
RoboRealm replied to my bug report, and they have already fixed the bug! If you download the latest copy from their website, it supports all 24 channels. (Note that they might not have updated the version number yet.)
- Ryan
Ryan,
Thanks it works fine on all 24 servos now.
One of the reasons I chose the P24 for this project
was because of the roborealm module.
Arobo
