Roboclaw and Motion Studio Software
Hi last week I purchased a RoboClaw 2 x 7 amp from Pololu robotics and have been experiencing problems getting it commissioned (maintaining a connection) with Motion Studio. I have contacted BasicMicro but just thought someone on this group might have some useful experiance. Thanks Barry
App 2.0.1.3; MCP FW 1.4.9; RC FW 4.4.9 and CR 2018.
On my desktop (W11 latest update build 26100.9711) I seem to have problems getting a stable connection with Motion Studio. Roboclaw connects, allows me to update firmware, sense ambient temperature but then stops 90% of the time, just freezes. I have tried cables, looking at USB numeration issues, powered hub vs mainboard usb, usb isolation (olimex) etc but cant seem to find whats happening (twenty of more years with microcontrollers, flasing problems etc). The driver file download provided did not improve things. Sometimes after 5 minutes motion studio starts up again and the freezes. Obvioulsy I cant see how I am going to get through servo tuning like this. The main supply to the Roboclaw has been 10V at up to 0.5 amps when connecting via the USB and Motion Studio. Any suggestions? Could there be a baud rate mismatch between the motion mind software and usb-com port driver?
Baud-rate mismatch may not be the problem. RoboClaw uses USB CDC communication. USB communication doesn’t depend on serial baud settings. First, check Device Manager during each freeze. Does RoboClaw disappear, or remain listed? Also, verify Motion Studio’s version and firmware compatibility. If there is another Windows computer, try that. Check supply voltage stability during USB communication. Electrical noise could also affect USB reliability. This Guide to electronic cables explains shielding and signal integrity. It helps identify potential cable-related interference problems. BasicMicro also recommends dual-ferrite USB cables. You can find more info in Roboclaw user manual
Hi thanks for the response, it seems to be an issue with my desktop for some reason. Same cables, same config, same operating system on my laptop its fine. I would have tried the laptop earlier but its having a few cmos problems (less than 1 year old HP omnibook). At least now I can get to the motor tuning and setup stage. Other issues aside the desktop has worked fine with every other micro and servo amp I have put in its path using custom software and even can bus emulation via usb. But that can be the way of things, as I learnt 40 years ago trying to get an ADC to work on an Apple 2e using 6502 assembler :slight_smile:
