I have a high powered motor driver that i can not get to work. The fault flags are FF=LOW FF2=HIGH. According to the table on the products page that means there is a short circuit. I am unable to clear the fault flags and reset the board. Either I dont know how to reset it or the board short circuits again. The page says I need to bring the reset pin from high to low. How do I do that? Just put a high into it? Also I have another driver hooked up the exact same way and it works fine.
Has the driver board ever worked for you? Can you describe everything you have connected to the driver? Please disconnect everything from the board except for power and tell me what the fault flags do after you cycle power.
- Ben
