Hi there,
Can anyone provide any info on using the Qik 2s12v10 with an Arduino? I’ve tried every documented method for transmitting serial to the Qik, but I’ve had no success.
Can you be a bit more specific about what you’ve tried and what the result was? I know someone wrote a library for using the qik 2s9v1 with the Arduino; maybe you can use that as a starting point? In general, you probably should be using the Arduino’s software serial library to send commands to the qik since the board’s hardware UART is used for programming (via the bootloader) and communication with the Arduino IDE.
code.google.com/p/qik2s9v1arduino/
I haven’t looked at the code or tried it myself, so I can’t vouch for its quality or functionality.
- Ben
