I’m having trouble getting my VNH3SP30 to drive my motors. I am using the IO pins of an ATMega32 to control the motor controller. The problem seems to be with how I’m sourcing the PWM signal.
In my setup, for power I have 5 volts on the ATMega32 board and have 9 volts connected to VIN on the motor controller board.
On the smaller pins on the VNH3SP30 I have 5volts coming from the ATMega32 board into the “+5v (IN)” pin and I have the grounds connected together. (Motor controller pins 1Diag/EN, 1inB, Vin (little pin), and 1CS are currently unconnected if that matters.)
I have one ATMega32 IO pin going to 1inA and one IO pin going to the 1PWM. When I pull both pins high (so using 100% duty cycle), the motor does not run. If I bypass the ATMega32 and move the 1PWM to come directly from the 5v battery pack the motor runs. (This shows the board works. Also, I have verified both IO signals are actually high, 5v, using a meter.)
Could it be that I’m not able to source enough current from the ATMega32 to input into the VNH3SP30’s PWM? The ATMega32 says it can source 40 mA and the VNH3SP30 says it needs around 10 uAs so I don’t know what is wrong.
Thoughts?
