Previously I posted a simple subroutine to control motor speeds using PWM on TIMER1 on the Orangutan. However, TIMER1 is the only 16 bit timer and is very useful for controlling servos or for other high precision requirements.
On the newer versions of the Orangutan (using the mega168), either TIMER0 or TIMER1 can be used for motor control. Hence, I offer a new version of the PWM subroutine using TIMER0, freeing up TIMER1 for other purposes. This version will not run on the older Orangutan with the mega8 chip, because TIMER0 does not have a PWM mode.
It should work on the Baby O, but I have not yet tested it. I suggest to set TCCR0B=3 to prescale the CPU clock by 64 in this case; see pwm_init().
Code with tabs can be downloaded from
uoxray.uoregon.edu/orangutan/pwm_direct_t0.c
Regards, Jim
/* pwm_direct_t0.c
** PWM routines for ORANGUTAN motor controller from Pololu
** atmega168/LB1836M motor controller, WinAVR
** these routines use TIMER0 in phase correct PWM mode, no interrupts
** by Jim Remington (sjames_remington _at_ yahoo dot com)
** for more information, see [uoxray.uoregon.edu/orangutan](http://www.uoxray.uoregon.edu/orangutan)
#include <avr/io.h>
#define F_CPU 8000000UL
#include <util/delay.h>
** pwm_init - Set up the pwm ports (PORT B1=IN1, B2=IN3, D5=IN2, D6=IN4)
** Initialize Timer 0 to phase correct PWM mode 1
void pwm_init( void )
DDRB |= 6; //set PORTB.1 and PORTB.2 to output
PORTB &= ~6; //clear outputs
DDRD |= (3<<5); //set PORTD.5 and PORTD.6 to output
PORTD &= ~(3<<5); //clear outputs (motor driver is now off)
TCCR0A = (1<<WGM00); //8 bit pwm phase correct, timer outputs disconnected from PORTD
TCCR0B = 2; //Timer increments at CPU clock/8, overflow frequency = 3.9 KHz
//TCCR0B = 3 for Baby Orangutan (clock/64)
OCR0A = 0; //clear compare match registers
OCR0B = 0;
pwm_set(signed int left, signed int right) - Set the two PWM speeds.
Each speed ranges from -255 to 255, NO CHECK is performed for |speed| > 255
right motor = PB.1(IN1) and PD.5 (IN2, OC0B)
left motor = PB.2(IN3) and PD.6 (IN4, OC0A)
If direction of travel is wrong, switch motor leads, but note asymmetry of PWM modes
in forward and reverse directions. Brake mode is more power-hungry but more power at low speed.
Truth Table for LB1836 controller from data sheet.
IN1/3 IN2/4 MODE
1 0 forward
1 1 brake (both outputs low), power hungry mode.
0 1 reverse
0 0 coast (both outputs off), power saving mode.
void pwm_set( signed int left_speed, signed int right_speed )
if ( right_speed > 0 ) {
PORTB |= (1<<1); //IN1=1
TCCR0A |= (3<<COM0B0); //set COM0B0=COM0B1=1: OC0B=IN2=0 on upcount, 1 on compare match
OCR0B = right_speed; //(this should be forward on upcount, brake on compare match)
if ( right_speed==0 ) {
TCCR0A &= ~(3<<COM0B0); //disconnect PWM channel B from PORTD
PORTB &= ~(1<<1); //IN1=0 ; set coast mode
PORTD &= ~(1<<5); //IN2=0
if ( right_speed < 0 ) {
TCCR0A |= (1<<COM0B1);
TCCR0A &= ~(1<<COM0B0); //set COM0B1=1, COM0B0=0: OC0B=IN2=1 on upcount, 0 on compare match
OCR0B = (-right_speed); //(this should be reverse on upcount, coast on compare match)
if ( left_speed > 0 ) {
PORTB |= (1<<2); //IN3=1
TCCR0A |= (3<<COM0A0); //set COM0A0=COM0A1=1 Result: OC0A=IN4=0 on upcount, 1 on compare match
OCR0A = left_speed; //(this should be forward on upcount, brake on compare match)
if ( left_speed==0 ) {
TCCR0A &= ~(3<<COM0A0); //disconnect PWM channel A from PORTD
PORTB &= ~(1<<2); //IN3=0 ; set coast mode
PORTD &= ~(1<<6); //IN4=0
if ( left_speed < 0 ) {
TCCR0A |= (1<<COM0A1);
TCCR0A &= ~(1<<COM0A0); //set COM0A1=1, COM0A0=0: OC0A=IN4=1 on upcount, 0 on compare match
OCR0A = (-left_speed); //(this should be reverse on upcount, coast on compare match)
** MAIN. Exercise left and right motors.
int main(void)
signed int i;
pwm_init();
while(1)
for(i=0;i<255;i++)
pwm_set(i,i);
_delay_ms(20);
for(i=255;i>0;i--)
pwm_set(i,i);
_delay_ms(20);
for(i=0;i<255;i++)
pwm_set(-i,-i);
_delay_ms(20);
for(i=255;i>0;i--)
pwm_set(-i,-i);
_delay_ms(20);
return 0;
