Hi
Seen can set multiple servo with appropriate protocol, with micro maestro 12 ,and no see multiple input protocol .
I would like if can realize this multiple input reception with appropiate protocol for serial comand.
Thank
Hi
Thank
Hi.
No, we do not have a command that allows you to check more than one input at a time. You can use the Get Position command to access each input separately. You can find out more about the Get Position command in the Pololu Maestro Servo Controller User’s Guide in the “Serial Servo Commands” section on the Maestro’s product page under the “Resources” tab.
-Derrill
OK not possible …
thank for you reply Derrill.
