I have been trying to learn a bit about TCL/TK GUI programming and found you example. I have a questions about the “connect” command on about the 4th line of the ssc-tester.tcl file.
At first I assumed that is referring to the “sys/socket.h” connect command, but when I manually open tclsh, load “ssc-tester.so”, and “connect” I get a print statement from connectProc.
I’m a bit of a newbie to tcl, does this mean that tcl calls to the c-library strip the term ‘Proc’ from a c-function name and apply some sort of default parameters? Where are those parameters defined?
Thanks in advance.
Cheers,
Peter
