Program help pls,Micro Maestro 6-Channel Servo Controller
Hi Guys
I hoping someone can help me out with some programming. I have a Micro Maestro 6-Channel USB Servo Controller. I have a push button on channel 0. I have a Continuous Rotation Servo on Channel 1. The servo position for off is 1492. This is what I’d like to do
Press the button
Wait 3 seconds
Spin the servo 360 degrees, direction doesn’t matter, then stop the servo.
Wait for the button to be pushed again
Wait 3 seconds
Spin the servo 360 degrees, direction doesn’t matter then stop the servo.
And so on
Any help would be greatly appreciated
Here’s my Ironman form 2 years ago
Hi Guys. I can’t find the guy who helped me with my Iron Man programming so if anyone can help with 360 degree program that’d be awesome. .
I’ve been asked for the code for the Ironman helmet. Here it is. As I mentioned an acquaintance wrote this and I paid him for it. The servers had to run in mirror opposite directions but together because of how they were mounted.
Channel 0 - Servo 1
Channel 1 - Servo 1
Channel 2 - Push Button Switch
Channel 3 - Eyes
Channel 4 - Arc Reactor
Operation
The start position is always “visor up, eyes and Arc reactor off ”
Press the button to run the servos to close the visor.
Visor closed “then” the Arc reactor lights up
then the lights in the eyes flicker a little then stay on.
Press the button again to run the servos to open the visor.
At the same time the lights in the eyes flicker a little then turn off.
Visor open
Then the Arc reactor turns off
This is the start position
Program
servo_reset
lights_off
servo_reset
main_loop
quit
### servo control subroutines
sub servo_reset
	#reset servos to mid position
	500 delay
	4000 4000 set_servos
	return
sub servo_gate_open
	#move servos in the opposite direction
	500 delay
	4000 8000 set_servos
	return
sub servo_fin_right
	#move both servos to the left
	500 delay
	8000 8000 set_servos
	return
sub set_servos
	#consume two stack values to run servos
	1 servo 0 servo
	return
### Button stadfte read subroutines
sub button
	2 get_position 511 less_than
	return
sub wait_for_press
	wait_open
	wait_close
	return
sub wait_open
	get_ms
	begin
	button
	if
	drop get_ms
	else
	if drop return endif
	endif
	repeat
	return
sub wait_close
	get_ms
	begin
	button
	if
	else
	drop get_ms
	endif
	repeat
	return
### light control
sub eyes_on
	8000 3 servo
	return
sub eyes_off
	2000 3 servo
	return
sub arc_on
	8000 4 servo
	return
sub arc_off
	2000 4 servo
	return
sub eyes_flicker
	eyes_on
	20 delay
	eyes_off
	180 delay
	eyes_on
	40 delay
	eyes_off
	160 delay
	eyes_on
	80 delay
	eyes_off
	120 delay
	return
sub lights_off
	arc_off
	eyes_off
	return
sub main_loop
	#Test function: control light with a button
	begin
	wait_for_press
	led_on
	arc_on
	1000 delay
	servo_fin_right
	500 delay
	eyes_flicker
	eyes_on
	led_off
	wait_for_press
	led_on
	eyes_off
	500 delay
	servo_reset
	500 delay
	arc_off
	led_off
	repeat
	return
I am not sure I understand what you are asking. Did you want the script you posted to be modified to include the functionality you mentioned in your first post?
Also, it is typically more difficult to turn the continuous rotation servos exactly 360° since you do not have position feedback in most cases. You will most likely have to send them a command to rotate, and time how long a full rotation takes. Then, you can delay for that amount of time before sending a command to stop the rotation.
-Brandon
Hey Brandon
No I was just posting the Ironman script for those interested.
For my new project I modified a servo to spin 360. You’re 100 percent right on the positioning. Without the pot the program has no way of knowing the location. I’m new to all this. I did get it working though. I fumbled through the examples and used the sequence function. There is prolly a bunch of code in this that isn’t required but it works and I’ll mess with it after Halloween.
goto main_loop # Run the main loop when the script starts (see below).
# This subroutine returns 1 if the button is pressed, 0 otherwise.
# To convert the input value (0-1023) to a digital value (0 or 1) representing
# the state of the button, we make a comparison to an arbitrary threshold (500).
# This subroutine puts a logical value of 1 or a 0 on the stack, depending
# on whether the button is pressed or not.
sub button
0 get_position 500 less_than
return
# This subroutine uses the BUTTON subroutine above to wait for a button press,
# including a small delay to eliminate noise or bounces on the input.
sub wait_for_button_press
wait_for_button_open_10ms
wait_for_button_closed_10ms
return
# Wait for the button to be NOT pressed for at least 10 ms.
sub wait_for_button_open_10ms
get_ms # put the current time on the stack
begin
# reset the time on the stack if it is pressed
button
if
drop get_ms
else
endif
repeat
# Wait for the button to be pressed for at least 10 ms.
sub wait_for_button_closed_10ms
get_ms
begin
# reset the time on the stack if it is not pressed
button
if
else
drop get_ms
endif
repeat
# An example of how to use wait_for_button_press is shown below:
# Uses WAIT_FOR_BUTTON_PRESS to allow a user to step through
# a sequence of positions on servo 1.
main_loop:
begin
5900 frame
6000 frame
repeat
sub frame
5 servo
### Sequence subroutines: ###
# Sequence 0
sub Sequence_0
  500 0 0 0 0 6000 frame_1..5 # Frame 0
  1650 6343 frame_5 # Frame 1
  500 6000 frame_5 # Frame 2
  return
sub frame_1..5
  5 servo
  4 servo
  3 servo
  2 servo
  1 servo
  delay
  return
sub frame_5
  5 servo
  delay
  return
