I moved your post to its own thread since it didn’t seem connected to the others.
It looks like you are specifying your delay parameter twice for each subroutine (once in your main BEGIN/REPEAT loop and once inside each subroutine). This means that after each subroutine there is a leftover value on the stack that is not getting used, eventually causing a stack overflow. Can you try either removing the 500 that starts each line in your BEGIN/REPEAT loop or removing the 100 before each delay in your subroutines?
Thanks for the prompt response !
Both indicated variants work.
But:
I want to use this program to synchronize multiple robot arms.
For this, I think, is important to keep that 500 at the beginning of each line in the BEGIN/REPEAT loop (which will then be modified depending on how big the move is).
But the elimination of the value before each delay in the subroutines leads me to a slowdown of the orders (I think a delay without specified value, automatically implies a delay of 1 sec.).
After me, a solution would be if in the compiled code I would change the delay code (08) in a lower value.
But I do not know how to do it.
Could you suggest a possibility, or another variant ?
I have to tell you that I am in the beginning using the controller maestro and I’m not too advanced in programming.
The 500 and 100 values that you are referring to are both intended to be used with the DELAY command to specify the duration in milliseconds, but the DELAY command only takes one argument. So, for example, when you remove the 100 value in each subroutine, the delays are all using the 500, resulting in a 500ms delay. You can reduce this delay by simply reducing 500. You can change each 500 in your main BEGIN/REPEAT loop to different values to specify the duration for each subroutine individually.
Please note that the DELAY command does not have a default behavior if you do not specify a value. If there is a value on the stack, it will use that value, otherwise it will trigger an error.
