I’m using this source code to start however when I click the send button the lights do flash on the USB-TTL adapter indicating the command was sent however nothing happens on the Maestro: colinkarpfinger.com/blog/?s=pololu
I’m powering the Maestro with an external 5 volt power supply.
The program you are using is written for a different servo controller, so it’s not surprising it doesn’t work. Please see the Maestro user’s guide for information about the Maestro serial commands.
Also, the Maestro has a USB connector and will show up on your computer as a virtual COM port, so you don’t need an additional USB-to-serial adapter. If you configure the Maestro to be in the proper serial mode, you can send serial commands directly to the Maestro’s appropriate COM port. Once again, you can find more information about this in the Maestro user’s guide.
You don’t have to start from scratch, you just need to modify the specific bytes that are being sent to be actual Maestro commands as documented in the Maestro user’s guide. Think of Colin’s code as an example of how to send data, and now you just need to pick the values of those data.
If you want an even simpler example of how to send serial bytes using .NET, take a look at the example code at the bottom of this page of our USB AVR Programmer’s user’s guide. This code shows how to transmit two bytes on the serial port. You could make your version even simpler by removing the lines that waits for a response and display it in a message box. If you want to transmit the three bytes 14, 92, and 87, you would use the line:
port.Write(new byte[]{14, 92, 87}, 0, 3);
If you have any specific questions about the Maestro serial commands or the .NET example, please let us know.
