Recently I’m trying to use Pololu Simple High-Power Motor Controller 18v7 to control the motor of an RC car. I can use the
Mini Maestro 12-Channel USB Servo Controller to control the steering servo using the code below:
void setPosition(int position, int servo)
const unsigned short vendorId = 0x1ffb;
unsigned short productIDArray[] =
0x0089, 0x008a, 0x008b, 0x008c
libusb_context *ctx = 0;
libusb_device **device_list = 0;
libusb_init(&ctx);
int count = libusb_get_device_list(ctx, &device_list);
for (int i = 0; i < count; i++)
libusb_device *device = device_list[i];
for (int Id = 0; Id < 4; Id++)
if (deviceMatchesVendorProduct(device, vendorId, productIDArray[Id]))
libusb_device_handle *device_handle;
libusb_open(device, &device_handle);
libusb_control_transfer(device_handle, 0x40, REQUEST_SET_TARGET,
position *4, servo, 0, 0, (ushort)5000);
libusb_close(device_handle);
break;
libusb_free_device_list(device_list, 0);
libusb_exit(ctx);
void setSpeed(int speed, int servo)
libusb_init(&ctx);
REQUEST_SET_SERVO_VARIABLE, speed *4, servo, 0, 0, (ushort)5000);
break;
libusb_exit(ctx);
However, I have no idea how to rewrite the libusb_control_transfer function to set the speed of the smc. I saw sentence like
controlTransfer(0x40, (byte)uscRequest.REQUEST_SET_SERVO_VARIABLE, value, servo);
in Usc.cs and the corresponding libusb command is
and it works fine; I also found
controlTransfer(0x40, (Byte)SmcRequest.SetSpeed, speed, (Byte)direction);
in Smc.cs, so I wrote the following program to control the motor:
#include <unistd.h>
#include <stdlib.h>
#include <curses.h>
#include <iostream>
#include <libusb.h>
#include "protocol.h"
using namespace std;
bool deviceMatchesVendorProduct(libusb_device *device, unsigned short idVendor,
unsigned short idProduct)
libusb_device_descriptor desc;
libusb_get_device_descriptor(device, &desc);
return idVendor == desc.idVendor && idProduct == desc.idProduct;
void safeStart(bool active)
0x98,0xA1,0x9C,0x9E
libusb_init(&ctx);
REQUEST_SET_USB_KILL, (active ? 1 : 0),0, 0, 0, (ushort)5000);
break;
libusb_exit(ctx);
void setSpeed(int speed, int direction)
0x98,0xA1,0x9C,0x9E
libusb_init(&ctx);
REQUEST_SET_SPEED, speed *4, direction, 0, 0, (ushort)5000);
break;
libusb_exit(ctx);
int main()
int direction;
int speed;
bool active;
cout << "Activate motor: ";
cin >> active;
cout << "Set speed: ";
cin >> speed;
cout << "Set direction: ";
cin >> direction;
// DIRECTION_FORWARD 0
// DIRECTION_REVERSE 1
// DIRECTION_BRAKE 2
safeStart(active);
while(1)
setSpeed(speed, direction);
return 0;
However, it doesn’t work (Compiled successfully ). I tried SmcCenter, it works fine, so no connection or powering problems. Can someone tell me what’s wrong with my program?
