I am using the Micro Maestro 6- channel servo controller to control two servos. I want to change the speed of the first servo across different frames. The first servo should go to position A at a slower speed and then back at full speed. I have checked the documentation and read some forum posts and have managed to write a script which works. The problem arises when I want the first servo to go to position A and back at full speed (no speed restrictions). The script does not work when i set the speed to 0, but works for other speeds (5,10,15 etc.) The script runs when i “step through” it but not when I hit “Run Script”. Any help would be appreciated. I have posted the code below.
# new setup C bend w/ fb variable stage 1 speed
begin
10 2 0 3 speed speed # does not work if speed of servo 2 is set to 0 at the beginning
5240 8000 frame_0_2..4 # Frame 0
moving_wait
0 2 0 3 speed speed #waits till servo 2 stops moving and changes speed of servo 2 from 10 back to 0
800 6208 3968 frame_2_3 # Frame 1
200 8000 frame_3 # Frame 2
repeat
sub frame_0_2..4
3 servo
2 servo
return
sub moving_wait
begin
get_moving_state
while
# wait until it is no longer moving
repeat
return
sub frame_2_3
3 servo
2 servo
Delay
return
sub frame_3
3 servo
delay
quit
