I wrote some code to test working with the Pololu QTR-8RC IR Sensor (shown below). I expected the binary display to go quickly to zero and the counter display to show how many counts to get to 0. However, if I move the sensor over a black and white surface, the binary display of PC0 and PC1 can switch back and forth betwen 0 and 1. I thought based on the sensor notes, once at zero, the sensor must be reset to 1 before switching back to a 0. Am I missing something?
* Orangutan LV-168 Program: IR Test *
* PURPOSE: This program provides a test routine to read a Pololu QTR-8RC *
* IR Sensor (2 sensor chip) and display the timing values on the LCD *
* CONNECTIONS: PC0 - Left Sensor *
* PC1 - Right Sensor *
* BUTTON0 - Button 0 *
* CHANGE RECORD: *
* DATE DEVELOPER CHANGE *
* 16 Apr 2008 Romeo Initial Development *
// F_CPU tells util/delay.h our clock frequency
#define F_CPU 20000000UL // Orangutan LV-168 frequency (20MHz)
#include "device.h"
#include <avr/io.h>
#include <util/delay.h>
#include "lcd.h" // provides routines for using the LCD
//IR Sensor Inputs
#define PC0nPC1 ((1 << PC0) | (1 << PC1)) //Pins 0 & 1 on PORT C
// Onboard Buttons:
#define BUTTONS ((1 << BUTTON0) | (1 << BUTTON1) | (1 << BUTTON2))
// Set button pins as inputs and enable pullups on those pins
#define initButtons() BUTTON_DDR &= ~BUTTONS; BUTTON_PORT |= BUTTONS
#define checkForButton() ( ~BUTTON_PIN & BUTTONS )
void ReadIRSensor()
// Initialize Variables
unsigned char IR;
unsigned char newIR;
unsigned int ctr = 0;
// Set the I/O line to an output and drive it high
// Allow at least 10 us for the 10 nF capacitor to charge
DDRC |= PC0nPC1; // Set PC0 & PC1 as Output
PORTC |= PC0nPC1; // Set High
_delay_us(10);
// Make the I/O line an input (high impedance)
DDRC &= ~PC0nPC1; // Set PC0 & PC1 as inputs
PORTC |= PC0nPC1; // Enable pull up resistors (Reads High)
// Measure the time for the capacitor to discharge by waiting for the I/O line to go low
lcd_clear();
IR = (PINC & PC0nPC1);
lcd_gotoxy(0,1);
lcd_binary(IR);
while (IR != 0)
newIR = (PINC & PC0nPC1);
if (newIR != IR)
lcd_gotoxy(0,0);
lcd_int(ctr);
lcd_gotoxy(0,1);
lcd_binary(newIR);
IR = newIR;
ctr++;
int main()
unsigned char button;
initButtons();
lcd_init();
while (1)
lcd_clear();
lcd_gotoxy(0, 0);
lcd_string("Press 1");
while (!(button = checkForButton())); // wait for button press
_delay_ms(10); // debounce press
while (checkForButton()); // wait for button release
_delay_ms(10); // debounce release
if (button & (1 << BUTTON0)) // set motors based on trimpot
button = 0;
ReadIRSensor();
return 0;
