I built the Pololu Dual Serial Motor Controller (kit) and it seemed to work fine. Now a problem I’m having is that it starts to move and then stops. I suspect it might be over current? But why?
The motor I’m using is the Solarbotics RM3 driving the Tamiya gerabox which even at stall should only draw 0.8 A, well below the controller specs. If I mesure the current flowing is actually around .3 Amps.
Any suggestion? Overheating (it’s actually cold at touch).
Shall I add a L298N? How? Any PCB available?
Thanks
Michele
