I am trying to use potentiometer as on/off switch so that when the pot is on i can use a second potentiometer to control a servo motor.
i am using Mini Maestro, and i am trying to use the code on the controller’s guide page because i don’t really have experience with programming.
this the code i have so far, and it shows me overflow problem. ( ch0 is servo, ch1 is on/off pot, ch2 pot)
# Set the servo to 4000, 6000, or 8000 depending on an analog input when ch0. pot is on
begin
1 get_position # get the value of the pot, 0-1023
300 less_than
if
2 get_position
dup 300 less_than
if
4000 # go to 4000 for values 0-299
else
dup 600 less_than
if
6000 # go to 6000 for values 300-599
else
8000 # go to 8000 for values 600-1023
endif
endif
endif
0 servo
drop # remove the original copy of the pot value
repeat
I would appreciate if someone points to me what i am doing wrong. Thanks
