I send the following command to the Qik2S12V10 controller:
0xAA 0x0A 0x02
to reset an error and get a response what problem the error cause. It is in autodetect baudrate, that’s why the preceding 0xAA is there. 10 is the default id number of the Qik and the 0x0A stands for that. 0x02 is the command for getting the error.
The weird thing is that the error led resets and stops burning and the qik is going back to normal operation. But no byte getting back with the errorreason.
So I am stuck with troubleshooting at step 2. I have done this with the Serial Transmitter Utility.
Disconnect the XBee from the qik and instead connect its TX line directly to its RX line. When you send bytes with the Serial Transmitter Program, do you get those same bytes echoed back?
If so, put the qik into demo mode and send bytes to the qik with the Serial Transmitter Program. Do you get those same bytes echoed back?
If you take the qik out of demo mode and send the command:
