Hi!
I’d like to connect Micro Maestro 6-channel USB Servo Controller with one servo to a timer.
Is it possible to run servo in a opposite ways every time when I turn the power on?
Example: I need servo to rotate in one way than I turn Micro Maestro off. Next time I switch Micro Maestro on I need servo to rotate in opposite way.
The Maestro does not have any kind of general-purpose permanent memory, so I do not see a way to do this. Is there a reason you cannot leave the Maestro on and trigger the motion with an input channel?
I need to start servo once in 24 hours at exact time. I want it to rotate in one way then wait 10 minutes and rotate it in opposite way. Next day I need to change the order of direction of rotation.
So I’m looking the simplest way to do this. I thought that Micro Maestro could help.
If I leave the Maestro on al the time, I need to know if there was a power break.
