Hi Guys and Gals,
I’m very, very new to coding and programming and robotics in general. I’ve combed over the literature and youtube videos and several posts to work on a new project I’m trying to complete. I have a Maestro Mini 12 channel microcontroller and the SparkFun MP3 trigger. It is connected to 4 buttons (which have been properly connected to ground and pull up resistors), 4 servos, and 4 pins of the Maestro are used as outputs for the MP3 trigger. I would like to activate a sound and motion at the press of each of the 4 buttons. The system would not need to run any of the actions simultaneously.
Button 1 would activate Servo 1 and Trigger MP3 1.
Button 2 would activate Servo 2 and Trigger MP3 2.
Button 3 would activate Servo 3 and Trigger MP3 3.
Button 4 would activate Servo 4 and Trigger MP3 4.
After reading through the guides for the MP3 trigger and the Maestro, I’ve come up with the following code. Would this work? Secondly, after the subroutine triggering the sequence, would the additional “sub” be necessary or could/should it be removed?
As you can see, I’ve put a lot of notes in the code, just for my reference as I am very new to this, which will be removed before the code is compiled to a script.
# Set inputs to channels 0, 1, 2, and 3
# Set outputs to channels 8, 9, 10, and 11
# Servo 1 Chan 4, Servo 2 Chan 5, Servo 3 Chan 6, Servo 4 Chan 7
begin
button_a if sequence_a endif
button_b if sequence_b endif
button_c if sequence_c endif
button_d if sequence_d endif
repeat
sub button_a
0 get_position 500 less_than
return
sub button_b
1 get_position 500 less_than
return
sub button_c
2 get_position 500 less_than
return
sub button_d
3 get_position 500 less_than
return
sub sequence_a
sub trigger_ascii
0x31 0x54 serial_send_byte serial_send_byte # Triggers sound 1 for sequence a
5 4 speed # Set speed of servo 1
4000 4 servo 1000 delay # First position of servo 1
0 4 speed # Set speed of servo 1
6000 4 servo 500 delay # Second position of servo 1
return
sub sequence_b
sub trigger_ascii
0x32 0x54 serial_send_byte serial_send_byte # Triggers sound 2 for sequence b
10 5 speed # Set speed of servo 2
8000 5 servo 1200 delay # First position of servo 1
5 5 speed # Set speed of servo 2
5000 5 servo 100 delay # Second position of servo 1
return
sub sequence_c
sub trigger_ascii
0x33 0x54 serial_send_byte serial_send_byte # Triggers sound 3 for sequence c
5 6 speed # Set speed of servo 3
4000 6 servo 1000 delay # First position of servo 3
0 6 speed # Set speed of servo 3
6000 6 servo 500 delay # Second position of servo 3
return
sub sequence_d
sub trigger_ascii
0x34 0x54 serial_send_byte serial_send_byte # Triggers sound 4 for sequence d
10 7 speed # Set speed of servo 4
8000 7 servo 1200 delay # First position of servo 4
5 7 speed # Set speed of servo 4
5000 7 servo 100 delay # Second position of servo 4
return
Here’s an example of what I mean.
The original code:
sub sequence_a
sub trigger_ascii
return
Code with additional sub removed:
sub sequence_a
trigger_ascii
return
Thanks! You guys are awesome!
