I’m working on a project with a pololu micro maestro, all i need it to do is turn two servos at the press of a button
I’ve never programed anything in my life and i’ve been basing everything on the example scripts from the manual but it still wont work, when i run the script the servos will do what i need to but when i disconnect it and press the button all that happens is one servo wiggles a little after 10 presses
My script looks as follows:
goto main_loop
sub button
0 get_position 500 less_than
return
sub wait_for_button_press
wait_for_button_open_10ms
wait_for_button_closed_10ms
return
sub wait_for_button_open_10ms
get_ms
begin
button
if
drop get_ms
else
if drop return endif
endif
repeat
sub wait_for_button_closed_10ms
get_ms
begin
button
if
else
drop get_ms
endif
repeat
main_loop:
begin
368 1300 frame
2256 1300 frame
repeat
sub frame
1 servo 2 servo
return
Is there something i’m doing wrong? Also when i plug in the batteries the yellow light blinks every second, i look in the manual but i dont quite understand if its normal or not.
Thank you!
