I have a NETDUINO Plus. Is Pololu Dual VNH5019 Motor Driver Shield for Arduino fully compatible with Netduino?
Is there a motor driver compatible with Netduino or any board with ethernet interface?
Thanks
Thanks
We haven’t tried it with a Netduino, but it seems like it should work (e.g. the motor driver’s PWM inputs connect to hardware PWM pins on the Netduino). I expect you’d need to write your own Netduino code to interface with the shield, though, since my understanding is that standard Arduino code (and hence our Arduino library) does not work with the Netduino.
If you try it, I’d be very interested in hearing how it goes (and seeing any code you come up with).
- Ben
