The #2130 DRV8833 Dual Motor Driver Carrier would not be a good choice if you are using a Raspberry Pi since the Raspberry Pi only has 2 hardware PWM pins and the DRV8833 carrier requires 4 PWM signals (2 for each motor channel). Although, you might be able to set up software PWM for this control method.
It should be fine to use either the DRV8835 Dual Motor Driver Carrier or DRV8835 Dual Motor Driver Kit for Raspberry Pi. You can use our Python libraries with either board as long as you make the same connections to the Raspberry Pi. One benefit of the #2753 expansion board is that it mounts directly on the Raspberry Pi GPIO header (like a HAT) to make the connections easier. It can also optionally power the Raspberry Pi base directly through an add-on regulator, which allows the system to be powered from a single power supply. Additionally, the motor connections can be made through the screw terminal blocks instead of soldering directly to the board.
