I have the code:
#include <SerialStream.h>
#include <string>
#include <iostream>
#include <stdlib.h>
using namespace LibSerial;
int main(int argc, char** argv){
SerialStream maestro;
maestro.Open("/dev/ttyACM0");
if (!maestro.good())
std::cerr << "[" << __FILE__ << ":" << __LINE__ << "] "
<< "Error: Could not open serial port."
<< std::endl;
exit(1);
maestro.SetBaudRate(SerialStreamBuf::BAUD_115200);
maestro.SetCharSize(SerialStreamBuf::CHAR_SIZE_8);
maestro.SetNumOfStopBits(1);
maestro.SetParity(SerialStreamBuf::PARITY_NONE);
maestro.SetFlowControl(SerialStreamBuf::FLOW_CONTROL_NONE);
char cmd[] = {0xAA, 0x0C, 0x04, 0x04, 0x70, 0x2E};
maestro.write(cmd, sizeof(cmd));
maestro.Close();
and I compiled it with g++ SimpleServo.cpp -L/usr/etc/lib -lserial. When I run the program with the controller connected, it doesnt move the servo at all. I know the servo and controller work because the command works fine using Pololu’s serial terminal. Are all of my settings correct? I wasn’t sure about Flow control, and there are also VTime and VMin that I haven’t messed with. I am running Ubuntu. Any help would be appreciated.
