I am still new to programming script, and I am not a programming.
Can someone help me convert this simple c# to script for masestro.
I try reading the manual, but this is as far I can go.
ANyway, thank in advance
begin
# Put servo position on stack
# Then call frame subroutine
2000 frame
4000 frame
8000 frame
repeat
sub frame
begin
3 get_position # Get analog sensor value
499 greater_than # Compare value >= 500
if
# Move servo 1 to position value on the stack
1 servo
return # Go back to return address
endif
repeat
The Maestro scripting language is similar to the stack-based programming language called FORTH, so you might try searching for more in-depth documentation on FORTH to get a better understanding of the Maestro scripting language.
Also, you might find it useful to use the “Step Script” button in the “Script” tab of the Maestro Control Center. The Step Script feature can be used to step through your script line by line so that you can see what happens at every step.
Also, we added code tags ([ code ] [ /code ] - without spaces) to your post; please use this method when posting code in the future.
