Mini Maestro 24 problem
From your description, it suspect you are seeing a power issue. What are you using as a power supply and how are you powering your servos?
You might try splitting your servos into separate banks if you have not done so already. Note that you will still need a common ground connection from those servos to the Maestro. You can see more details about splitting the power rail into banks in this forum post by jon.
