is it true, that i can only use one input per channel (servoconnector)?
In the drawings i see only one.
Thank you very much.
regards
Michael
regards
Michael
Hello, Michael.
I am not sure what you are asking. Are you asking about using the Maestro servo channel signal pins as inputs for signals? The signal pins of the Maestro are I/O pins of a microcontroller. Depending on the electrical properties of your outputs and what you are trying to achieve you can connect multiple ones to the Maestro. For example, if your outputs use an open-drain setup, you can have many of them on the same input.
If you post what you want to wire and how you want to wire it, I would be glad to take a look.
- Ryan
