Hi guys & girls
I have a mini maestro 12 channel servo controller on a robot project & when i
copy sequance to script / run script on start up / apply settings, then unplug
the usb cable nothing happens, the servo motors are running on 7.2 volt power supply,
unsure of what im doing wrong…AAHHHHHH…Many thanks…
How are you powering the logic side of the board? If you want to power the board from your servo power supply, you will need to connect VSRV and VIN using the blue jumper as shown in the picture below (indicated by the orange box):
By the way, most standard servos have an operating voltage range of 4.8V to 6V, so you might consider checking the operating voltage rating for your servos (just in case).
- Amanda
