yes your quite right… also should i put it in a loop or not… i tried the comands between 0-5 and i cant get anything to work. it just flashes at me intimidatingly… any other suggestions… it shouldnt be this hard. and i dont really understand what to put for the data bytes for the command… thank you
If you are having problems getting things working, try the simpler Scott Edwards protocol first. You don’t need to put anything in a loop. If you continue having problems and need help, you need to be more specific about what you are doing and what the result is.
