I am trying to build a project utililizing a laptop and the micro serial servo controller, but my laptop does nto have a DB9 (serial) connector. Can I use the DB25 (parallel) connector instead, if so what pin do I use for the data signal?
Unfortunately you cannot use a parallel port to talk to our micro serial servo controller. You will need to use a USB-to-serial adapter to connect your laptop to the controller.
