Hello, I started this project not even knowing code at all. I have gone through the sequences and copied the sequences to scripting. But I have no idea how to change the speeds between positions. The servo starts at position 1 waits for remote control push button activation to start the sequences. 2nd position is at 1/3 way at “7” “speed”. then it sits there for 7 seconds and then moves to position 3 at “12” “speed” all the way to end (end of - 90 degrees), and is supposed to immediately zip back as fast as possible back to position 1.
What I get is the zip speed between each position (100), and I have no earthly idea to modify the script to achieve this. I can see the script page, but I do not know how to edit it or then save it and download it to the Maestro. Little help? Thank you!
Below is the code thus far as much as I can reproduce:
0000: –
0000: –
0000: – ### Sequence subroutines: ###
0000: –
0000: – # Sequence 0
0000: – sub Sequence_0
0000: 030EF40100000000000000000000221981 – 500 0 0 0 0 0 6434 frame_0…5 # Frame 0
0011: 0304F401800F82 – 500 3968 frame_5 # Frame 1
0018: 0304F401401F82 – 500 8000 frame_5 # Frame 2
001F: 05 – return
0020: –
0020: – sub frame_0…5
0020: 02052A – 5 servo
0023: 02042A – 4 servo
0026: 02032A – 3 servo
0029: 02022A – 2 servo
002C: 02012A – 1 servo
002F: 02002A – 0 servo
0032: 08 – delay
0033: 05 – return
0034: –
0034: – sub frame_5
0034: 02052A – 5 servo
0037: 08 – delay
0038: 05 – return
0039: –
Subroutines:
Hex Decimal Address Name
00 000 0000 SEQUENCE_0
01 001 0020 FRAME_0…5
02 002 0034 FRAME_5
