Hey,
I have succesfully got this motor controller working for a 1 amp situation in single motor mode(on 0 motor mode). However, I am getting a new motor which will require 2 amps. How do i get the additional amp. I looked at the booklet to get instructions. However, when i measure the voltage and current from the two pins not currently hooked up to the motor i get 0. Is there something I have to code. Or is there something wrong with the product? Here is the code I used below. I found it online and dont fully understand it. All i know is that it only seems to work for motor 0 and not motor 1.
void InitMotor()
pinMode(txPin, OUTPUT);// Serial Transmit Pin
pinMode(resetPin, OUTPUT); // Motor Reset Pin
motorSerial.begin(9600);
// Reset the motor controller (By setting low then high signals to the resetPin)
digitalWrite(resetPin, HIGH);
delay(10);
digitalWrite(resetPin, LOW);
delay(10);
delay(10);
void SetMotor(int speed)
int motorIndex=0;
unsigned char buffer[4];// Create the packet buffer
unsigned char index = 0;
unsigned char targetSpeed = speed;
buffer[0] = 0x80;
buffer[1] = 0x00;
buffer[2] = 0x00 | index;
buffer[3] = targetSpeed;
SendPacket(buffer, 4);
void SendPacket(unsigned char *buffer, int bufferCount)
for(int i = 0; i < bufferCount; i++)
motorSerial.print(char(buffer[i]));
