Hey,
I have succesfully got this motor controller working for a 1 amp situation in single motor mode(on 0 motor mode). However, I am getting a new motor which will require 2 amps. How do i get the additional amp. I looked at the booklet to get instructions. However, when i measure the voltage and current from the two pins not currently hooked up to the motor i get 0. Is there something I have to code. Or is there something wrong with the product?
Did you send the command to change the motor controller to single-motor mode? Once you do that, you should see both sets of motor outputs doing something.
- Jan
